I cant get the drums on my 14 bolt off. I tried using the adjuster screw but its stuck too. Is there another way to get the drums off or should I just cut them? I already tried beating them with a mini sledge. Maybe I need a bigger hammer? They will move about 1/2" Any help would be appreciated
Announcement
Collapse
No announcement yet.
14 bolt drums stuck
Collapse
X
hmmm, if you can't get the adjuster to move to back the shoes off, then see if you can dismount the wheel cylinder and let it fall into the drum. This may allow the shoes to fall into the center a little more, giving you room to get the drum off.
Good luck... and forget the grinder... get a sawzall or a portaband or something....
