Ok I Had heat the other week now i dont check fuse its fine. Is there a relay under ther hood any info will help thanks tommy:confused:
Announcement
Collapse
No announcement yet.
Heat
Collapse
X
are both lines of your heater core hot1989 ext cab yota 22re bored .20 over trd cam, trd headers, Marlin crawler front bumper w/stinger, Marlin crawler roll cage, trailgear rear bumper, trailgear rock sliders, richmond 5.29's, and lockright rear, 33 nokian mt's. 10k winch. Rear disc conversion. Chromoly rear axle shafts. Bombproof motor mounts and transfer case mount. Whole lot of rust and scratches.
air pocket? you might try bleeding/burpping it.... Is there some kind of heater control valve that might not be working?
good lucksigpicchris hodges
SO ME AND DAN TOOK A LOOK AT MY BLOWER AND I WAS GOING TO GET A NEW ONE WELL TODAY I WAS DRIVING AND AS I WAS DRIVING THE HEAT WAS WORKING BU WHEN I STOPPED AT A RED LIGHT IT WOULD STOP BLOW HAS ANYONE HAS THIS PROBLEM BEFORE08 jeep Sahara soon to be with 33s
Originally posted by tom tom View PostSO ME AND DAN TOOK A LOOK AT MY BLOWER AND I WAS GOING TO GET A NEW ONE WELL TODAY I WAS DRIVING AND AS I WAS DRIVING THE HEAT WAS WORKING BU WHEN I STOPPED AT A RED LIGHT IT WOULD STOP BLOW HAS ANYONE HAS THIS PROBLEM BEFORE
sounds like it's just something silly... always the hard ones to find...
Did you try jumping 12 volts to the blower to see if it would stay working?
sigpicchris hodges
sounds like a bad blower motor...
I assume that when you say "no heat" that it is not blowing on any temperature setting? If the blower is not blowing, try hitting it with soemthing (dont break it) while it is supposed to be on. If it starts working it's going bad (similar to a starter with a bad spot) and needs replaced asap.
Originally posted by tom tom View PostSO ME AND DAN TOOK A LOOK AT MY BLOWER AND I WAS GOING TO GET A NEW ONE WELL TODAY I WAS DRIVING AND AS I WAS DRIVING THE HEAT WAS WORKING BU WHEN I STOPPED AT A RED LIGHT IT WOULD STOP BLOW HAS ANYONE HAS THIS PROBLEM BEFORE2000 Xterra, ARB Bumper, 2" bl, Wrangler MT/R's 32x10.5, Loadwarrior
