I think late 90s chev one ton trucks had 1350 rears... Could use those to build one
Announcement
Collapse
No announcement yet.
Parts to build your own Driveshaft
Collapse
X
Originally posted by humpy View PostI think late 90s chev one ton trucks had 1350 rears... Could use those to build one
Just an update on what I'm working on. Ordered some shaft and couplers from surplus center. 1 3/8" 21 spline. A 12" shaft and 2 couplings (2 1/4" long each) ran me right at $100 shipped to the door. Going to attempt to make a long slip shaft for one of my Toyotas this weekend.
Anyone have any tips for keeping everything fairly straight and true?JT Jones
83 Toyota - beater
87 Toyota Truggy
Originally posted by fastford View PostTry this place 874-3680 used to be drivetrain specialist, can't remember the new name, they are off 747 by speedway
Originally posted by Jonesy View PostJust an update on what I'm working on. Ordered some shaft and couplers from surplus center. 1 3/8" 21 spline. A 12" shaft and 2 couplings (2 1/4" long each) ran me right at $100 shipped to the door. Going to attempt to make a long slip shaft for one of my Toyotas this weekend.
That's the hard part. I usually just roll it back and forth and eyeball it. I would never notice a vibration with my tires though.
Anyone have any tips for keeping everything fairly straight and true?One of these days Zuk 2.0
Originally posted by 93 Krawler View PostIt's Power Clutch & Drive now. I called them yesterday to see if they can match a slip to my 16 spline shaft. I have to take it them and see if they have anything. If not, off to you pull...
I don't know if an 1 3/8 shaft would hold up in my rig. It would be nice if I could.
That's the hard part. I usually just roll it back and forth and eyeball it. I would never notice a vibration with my tires though.sigpic
For anyone interested in the ones mentioned by fabricator, here is a PDF to check out.Attached Files
Update on the drive shaft I built using the 1 3/8 spline from surplus center. It failed after 3 trips. I twisted the splines enough to lock it up. I hit a rut and it jammed the d shaft through the transfer case.
I ended up buyng the Neapco parts that fabricator mentioned from drivetrain america to build a new one. I worked it out so I could reuse the end yokes I had. This one is 1 5/8, so it better last...
