Announcement
Collapse
No announcement yet.
ORI Relocation
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • ORI Relocation
    Started the front shock relocation.
    Made some huge progress today. Got the front ORI and new engine cross brace completed.
    sigpic
  • #2
    Before and after pics.
    sigpic
    • #3
      More progress today. All welds are done, air tank and PS reservoir mounts made. Now I have to paint!
      sigpic
      • #4
        Paint and sub 50* weather are not friends!
        sigpic
        • #5
          Looks like you got it setup perfect now
          • #6
            Yep a lot of trial and error. Welding what I thought was the permanent location 3 times kinda sucked but I gained a lot of knowledge. Thank goodness I have a plasma cutter.
            sigpic
            • #7
              So the original locations were less than ideal (maybe I missed this in one of your other threads)
              1976 CJ 5
              1984 CJ 7
              1993 K3500 GMC 6.5 TD
              • #8
                This all started because I did not want to remove my shock hoops I have had for years because it entailed a whole lot of work. Not moving the shock hoops compromised compression and angles of the struts that caused severe body roll as well. So after my first run I did some searching for new shock towers and found Ruffstuff had a mandrel bent set for $120 that would make the relocation much simpler. The relocation ha only taken about 12 man hours to do. So I wish I would have done this from the get go. However I have learned a whole lot and the setup is spott on now.. At least on the lift.
                sigpic
                • #9
                  Keep that plow off and take it to haspin new years
                  • #10
                    If I was not going to be gone I would.
                    sigpic
                    • #11
                      ORI relocation completed.
                      sigpic
                      Working...
                      X
