Old 12-11-2010, 09:32 AM   #1
oklahomawelder
Tradin' Fool
Oklahoma buggy build
Thought I would post up some progress on my Yellowjacket Fab buggy slowly going together....
I will be running:
Motor: LS6
Trans: TH400
Tcase: Atlas 4.3
Axles: 60 FR & Rr
Gears: 5.13 detroit Fr&Rr
Suspensioin: 2.0 Fox 18" shocks 4-link Fr&Rr
Tires: undecided in 39"-40" flavor
Seats: Racetrim suspension seats
Steering: PSC full hydro
Name:	2010 NEW 2 SEAT BUGGY 006.jpg
ID:	3155   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 009.jpg
ID:	3156   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 014.jpg
ID:	3157   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 015.jpg
ID:	3158   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 012.jpg
Name:	2010 NEW 2 SEAT BUGGY 008.jpg
ID:	3160   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 010.jpg
ID:	3161   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 011.jpg
Old 12-11-2010, 10:50 AM   #2
lookin good. some of the pics are grainy- when that rear truss is done id like to see some close ups on that! are you leaving the belly as is or moving it around any?
Old 12-11-2010, 06:55 PM   #3
oklahomawelder
Tradin' Fool
I hope to leave the belly as is. I have noticed I will more than likely have to run a 2 pc front drive shaft and may end up having to move the front tube on that side of the belly, but not sure just yet....
After CHRISTMAS, (NOT HOLIDAY) I should be able to proceed pretty quickly. Shocks should be here next week, order some tube from RED 9, order my 6x3x1/4 rect tube for the trusses, 8 more 7/8" rod ends from Ruffstuff and get it in roller form and take it to my sheet metal guy to help with the firewall, floors and all....
Old 01-09-2011, 09:15 PM   #4
oklahomawelder
Tradin' Fool
Got all the links made and tacked in along with front and rear shocks and front and rear trusses. Tranny mount and some tube work in the rear also...
ID:	3236   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 013.jpg
ID:	3237   Click image for larger version
ID:	3238   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 016.jpg
ID:	3239   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 023.jpg
Old 01-09-2011, 10:13 PM   #5
simpletoy
Looks good man can't wait to see the finished product.
Old 01-10-2011, 10:45 PM   #6
oklahomawelder
Tradin' Fool
Thanks... I am hoping to finish up within the next 2-3 months...
Old 01-16-2011, 09:05 PM   #7
oklahomawelder
Tradin' Fool
Got the seats mounted today...
Name:	2010 NEW 2 SEAT BUGGY 001.jpg
ID:	3290   Click image for larger version
ID:	3291   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 004.jpg
ID:	3292   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 007.jpg
ID:	3293   Click image for larger version
Old 02-13-2011, 05:39 PM   #8
oklahomawelder
Tradin' Fool
Not much progress. Waiting on my fuel cell and radiator to get them mounted.
I did get my aluminum tube welded up for my coolant lines and got them mounted. They have -16 fittings on them. I will have -16AN threaded connections at the motor, on the tube and on the radiator with SS braided flex hose between engine and tube and tube and radiator.
Name:	2010 NEW 2 SEAT BUGGY 002.jpg
ID:	3376   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 003.jpg
ID:	3377   Click image for larger version
ID:	3378   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 005.jpg
ID:	3379   Click image for larger version
ID:	3381   Click image for larger version
Old 02-14-2011, 01:41 AM   #9
that will be like a seat heater for the passenger...
Looks good..
Old 02-14-2011, 02:11 PM   #10
oklahomawelder
Tradin' Fool
Looks good..
Thanks....
I will be bringing the floor pan all the way back under the seat so it will be between the seat and the tubing... Shouldnt let too much heat to the seat...
Old 02-26-2011, 09:24 PM   #11
oklahomawelder
Tradin' Fool
Well got to work on the buggy a little today... Picked up my Transmission on Friday, got my -16 fittings welded on my radiator this week and I finally got my fuel cell.
So I mounted the Fuel cell and mounted some motor mounts to the back of the heads on the motor.
Waiting on my radiator mounts to get it mounted and need to figure out a mount for my steering ram and pick up a set of High steer arms so I can get the steering mounted....
Also got my crawlfab beadlocks welded up and my steering valve mounted...
ID:	3485   Click image for larger version
ID:	3486   Click image for larger version
ID:	3487   Click image for larger version
Name:	2010 NEW 2 SEAT BUGGY 017.jpg
ID:	3488   Click image for larger version
Old 02-27-2011, 09:03 AM   #12
looking good!!!!!!
Old 02-27-2011, 09:33 PM   #13
underpowered
They call me......Scuba
pretty slick mounts on the heads there.
beat up rusted out k5
Old 02-27-2011, 10:28 PM   #14
oklahomawelder
Tradin' Fool
Thanks, I borrowed the idea from some other builders and had a shop in Ft Smith, Ar cut them out for me....
Old 06-25-2011, 07:31 PM   #15
oklahomawelder
Tradin' Fool
Its been a while since I have updated this. It is still in Ft Smith, I have CGYS doing quite a bit more than we originally planned, because I have been very busy with kids and sports.
They got all the headers built and exhaust is half way back. They are pretty sweet.
I didnt like the front truss and ram mount I had made so I had them get an ARTEC front truss and ram mount and put it on.... BEEFY..
4340 35 spline inner and outer shafts on the front 60 with Yukon Super Joints
Reid Knuckles
Artec High Steer arms
Yukon Drive flanges
I swapped out the rear 60 for a 70U with Artec truss and disc brakes as well
5.13 gears with Detroit
Front 2 piece Tom Woods driveshaft
Rear Tom Woods Driveshaft
1350 throughout
Rock equipment sway bar in the back
Mounting my Radiator
Swapped out the RaceTrim seats for PRP Competition High Back in the extra wide size with Ostrich Skin....
Also sold the steel beadlocks and bought a new set of aluminum Raceline beadlocks and a set of 40" Trepadors to go on it....
and looking at some other things as well.
I will get some pics up in the next few days....
shooting for fall to get it on the trail...
Name:	New Buggy 6-24-11 001.jpg
ID:	3929   Click image for larger version
Name:	New Buggy 6-24-11 002.jpg
ID:	3930   Click image for larger version
Name:	New Buggy 6-24-11 003.jpg
ID:	3931   Click image for larger version
Name:	New Buggy 6-24-11 004.jpg
ID:	3932   Click image for larger version
Name:	New Buggy 6-24-11 005.jpg
Old 06-25-2011, 07:34 PM   #16
oklahomawelder
Tradin' Fool
More....
Name:	New Buggy 6-24-11 006.jpg
ID:	3934   Click image for larger version
Name:	New Buggy 6-24-11 007.jpg
ID:	3935   Click image for larger version
Name:	New Buggy 6-24-11 008.jpg
ID:	3936   Click image for larger version
Name:	New Buggy 6-24-11 009.jpg
ID:	3937   Click image for larger version
Name:	New Buggy 6-24-11 010.jpg
Old 06-25-2011, 07:37 PM   #17
oklahomawelder
Tradin' Fool
And the last one for now....
Name:	New Buggy 6-24-11 011.jpg
ID:	3939   Click image for larger version
Name:	New Buggy 6-24-11 012.jpg
ID:	3940   Click image for larger version
Name:	New Buggy 6-24-11 013.jpg
ID:	3941   Click image for larger version
Name:	New Buggy 6-24-11 014.jpg
Old 06-26-2011, 12:03 AM   #18
those headers are cool as he**...
It's looking good...
Old 06-26-2011, 12:18 AM   #19
oklahomawelder
Tradin' Fool
Thanks....
I thought he did a very good job on the headers. The driver side runs forward on the rear cylinder to try and get as much foot room as possible.....
Old 06-26-2011, 08:52 AM   #20
Exclamation
Lookin good brannon. What's next?
Old 06-26-2011, 09:13 AM   #21
oklahomawelder
Tradin' Fool
Thanks Rob....
Still have to install the Rock Equipment sway bar
Finish front axle
finish Radiator Mount
Bolt in the new PRP's
Mount pedal and MC's
Aluminum interior
Then tear down and weld it all up
It is getting closer....
Old 06-28-2011, 09:05 PM   #22
mossyoaktj
mossyoaktj's Avatar
that thing is gnarly
UNITED STATES MARINE
Old 06-28-2011, 09:36 PM   #23
Looks good in those pics u sent me. Was that full stuff on shocks I guess? I finnaly joined ur site and posted... def want closups of ur truss and arms...
Old 06-28-2011, 10:10 PM   #24
Where's the ball valves?
Old 06-28-2011, 10:55 PM   #25
oklahomawelder
Tradin' Fool
Yes that was on the shocks.
I will get better pics tomorrow with my camera of the front end and post them up....
