Ford front 60 and chevy 14 bolt built
The front is a Ford drivers drop high pinion ball joint dana 60 with new 5.13
gears and a new detroit locker. It has all new ball joints and rotors and needs one caliper. They have surface rust from sitting outside. The brake lines and hoses are all new as well. It has brand new USA chrome moly 35 spline axles inner and outer and the unit bearings have been redrilled for 8x6.5 pattern with a spare unit bearing. It won't have u-joints or lock outs. It has one high steer arm, and dom tubing between the knuckles with new tie rod ends. It has coil over mounts and link mounts and is set up for 3 link front with a panard bar. The rear is a 14 bolt with 5.13 gears and I was told some type of locker. The ring gear has been shaved but the housing has not. It has new disc brakes, rotors, calipers, hoses, lines. It has 1/2" plate truss, coilover brackets, and lower link brackets for 4 link, as well as leaf spring perches. It also has a nice pinion guard tied into the truss. I need $2K for the pair.
i will trade you a set of 4:56's for your 5:13's and you keep the lockers. i will even come up and do all the labor.
Bump
If anyones building, I still have these. You can't build them for anywhere close to this.
Would you be willing to seperate? I just need the 60.
Sale is pending. I want them to go as a pair, but if something changes, I will let you know.
The Rox Box
Do you still have them or did they sell.. Thanks
They are supposed to be picked up tomorrow night, at this point..
sold
Sold
