#1 | |
#2 | |
is great for going to the mall no bump steer or nuthin what you want for the full hydro junk
#3 | |
Danfoss steering valve, plate to bolt up valve and weld to frame, single ended ram, hoses to ram and valve, hoses from and to valve. Yours today for $200.00 2 bills only come and get it
Just some random oribital valve and a single sided tractor ram is most likely the absolute worse case you can have in regards to road manners.
Regarding legality, pretty sure there is nothing actually in writing stating specifically that hydraulic steering is illegal. Just like beadlocks... on Pirate4x4 there was a person/vendor offering a cash prize for the first person to reference any state law that specifically stated beadlocks were illegal, and that prize has yet to be claimed after several years. |
Full Hydro
You know my opinion for the trail, nothing beats full hydro. On the other hand for the road I would make sure your orbital valve has more the three turns on your steering wheel from lock to lock, little scary on the road. I'm not sure what it's called but get one that takes 5-7 turns lock to lock if using on the street.
#6 | |
I know for a fact it is illegal to alter/modify anything with a D.O.T stamp from it's originally approved design.
Beadlocks aren't illegal , hacking the bead off a non-lock wheel and welding a lock ring on is.... if it sees public roads. Running HMMWV beadlocks or any other Hutchinson brand two piece wheel is the only truly legal way to do it .... Don't know if this has changed but as of a couple years ago Hutchinson was the only true locking wheel with D.O.T approval. Full hydraulic steering laws change state to state... I've never been able to find it in writing if it's legal or not in Ohio. Some states require a 100% mechanical link between the steering gear and the operator. I ran full hydro on a woods rail that saw 80+ MPH many times , did it for years ... had a buddy with the same set-up on a rail that past a O.D.O.T inspection ... so ether it's legal or the inspectors don't ****.. ![]() Jeff |
[QUOTE=blazerbrad;25866]Just some random oribital valve and a single sided tractor ram is most likely the absolute worse case you can have in regards to road manners.
i second that...mine is NOT very streetable past 30mph but on the trail i LOVE IT!!! for under $300 bucks and turnin the wheel with one finger while layin on your side rocks!! ![]() |
I can run 70, but it's best in a straight line. I love the full hydro for my rig, although it is a little quirky on the highway through the curves. I ran hydro assist once before, and it drove great. It removed all the slop from the steering and made it very predictable and was quite strong as well. I damaged the ram and removed it, and ended up full hydro a couple years later.
