i will post up some pictures of the spring set up here soon, here s some of what I ve got now. some more info as well.
85 front axle 86 rear axle 36 tsl bias high steer trans case regeared to 4.7:1 low 4.88s with lockrite front and detroit rear 22RE better than stock birfields |
Runner looks good I sent you a PM
Too many projects
Try a stock sway bar or any junkyard sway bar that is the right width. Make your own end links. I personally have found that I like a rig better when one end of the rig is a little more stable. I don't believe that a super flexy suspension front and rear is always the way to go. Usually seems like the body sways all over the place and the rig is more tipsy. On the TJ that I had I kept the stock rear sway bar, it was just enough to keep the body more stable.
