#1 | |
sorry coach if i would had known i would have got them from you. ordered from dbelectric last nite. well see if they work may and try to pull winch apart this week. thanks matt
No prob. If those universal ones don't work out, I've got the Warn brand ones for ya. :)
Just another three linked stretched '95 YJ on 38s with a bunch of stuff scattered on the garage floor. |
well it worked for about 1 minute! then it is stuck on ! hooked up solnoids and it ran in and out several times out about 2 ft each time then back in , then it stuck on going in unhooked battery and reversed terminals to run it out! now what! i guess ill do some checking make sure i wired it right. then send them back i guess. anty suggestions? matt
If they worked correctly before for several cycles, then you've got them hooked up right. Probably just poor quality knock offs. Get the real Warn ones for a buck more. ;)
after tapping on them with a wrench they work for a few times then stick always going in. so ive got it narrowed down to 1 solnoid. i have 1 old one left that didnt break when removing. so ill switch them and hope it all works for the zukimelt! i hope we dont need a winch while there, but then if i dont need a winch we arnt having fun!!!!!! ill be calling coach!!!!! thanks guys !!! matt
