Old 07-04-2012, 10:40 PM   #1
NKYJEEPSTER
NKYJEEPSTER's Avatar
the beast
Well picked up this rig. It s a beast for sure
360 V8
4 speed
twin sticked transfer case
2" cage tied into frame
winch
5-42" TSL
rockwells front and rear
front suspension is leaf spring
rear suspension is quarter elliptic 4 link setup.
ID:	5548   Click image for larger version
Old 07-04-2012, 11:02 PM   #2
tjrider
That thing is gorgeous!
Old 07-05-2012, 12:37 AM   #3
frankensteinxj
frankensteinxj's Avatar
beautiful.
BYAAH!!!
Old 07-05-2012, 01:07 AM   #4
time to wheel it!!!
Old 07-05-2012, 10:28 AM   #5
lets go tough test it!! looks good
Old 07-05-2012, 07:30 PM   #6
NKYJEEPSTER
I ve got a few small things to fix on it and it ll be ready to roll. Never done work on a pinion brake before but doesn t look to hard. Just gotta figure out what caliper is on it. The rear one is leaking, bad piston seals.
Old 07-05-2012, 10:09 PM   #7
LP78CJ
LP78CJ's Avatar
My pinion kit used 86 yota front calipers, ive seen some others use chevy 3/4 ton as well so maybe one of those
Old 07-05-2012, 10:21 PM   #8
NKYJEEPSTER
thanks for the advice i ll check into it.
Old 07-05-2012, 11:15 PM   #9
Take a good pic of the caliper and post it up... i bet some one can identify it... I couldn't tell from the pic you have posted...
Old 07-21-2012, 05:09 PM   #10
NKYJEEPSTER
so I did a little flexing today to see what its capabilities are and.................
Old 07-21-2012, 05:13 PM   #11
NKYJEEPSTER
the first pic you can see the front of the slider is even with my shoudler, i m 6'2"
the rear suspension started out sitting level with 19.25 inches front bolt to bolt on the shocks, there is only 5 inches of up travel as it sits with the current shocks. I removed the shocks on the rear to see what it is capable of and in this pic the driver side rear axle dropped down to 39.75 inches from 19.25. So that s 20+ inches.
Oh yeah, sitting on the angle, it didn t feel a bit tipsy like it wanted to roll over, it feel pretty stable to me.
Old 07-21-2012, 08:24 PM   #12
NKYJEEPSTER
so from what I can figure, I need to start looking for some fox 2.0 16" or 18" travel shocks for the back, Need 2 if anybody s got any.
Old 07-21-2012, 11:46 PM   #13
frankensteinxj
waaaaant!!!!
BYAAH!!!
