Old 12-23-2009, 07:39 PM   #1
What coils should I use?
I am building my Sammy Buggy and am almost positive that i am going to go ahead and foru link the front. The rear is already done but I am going to redo it.
What coil springs should I use? I lan on running coil overs or air shocks later but do not have the $$$ right now.
Thanks!
Old 12-23-2009, 07:48 PM   #2
JET455
Your wifes pimp!
JET455's Avatar
I would use some stock TJ springs im sure you can almost get them free or cheap.
Old 12-23-2009, 09:22 PM   #3
KennyTJ
The Pirate
KennyTJ's Avatar
I have a set of stock TJ spring, PM me if your interested.
Old 12-23-2009, 09:27 PM   #4
TJ Springs...
That is what I was thinking....
Old 12-24-2009, 07:50 AM   #5
tinbeater
tinbeater's Avatar
Thanks!
I use 175 front & 150 rear QA1's with good results. Both are 14 inches long.
Old 12-24-2009, 09:16 AM   #6
same ones i use and have for about 4.5 years with no problems at all plus with only being about 3.5" in diameter they are easy to place on the axle
Old 12-24-2009, 10:58 AM   #7
Nuts's Avatar
Rear soft top tracker/sidekick springs are 150s. Chris C. has them at all 4 corners and his Sammy does awesome!
