What coils should I use?
I am building my Sammy Buggy and am almost positive that i am going to go ahead and foru link the front. The rear is already done but I am going to redo it.
What coil springs should I use? I lan on running coil overs or air shocks later but do not have the $$$ right now. Thanks! ![]() |
Your wifes pimp!
I would use some stock TJ springs im sure you can almost get them free or cheap.
The Pirate
I have a set of stock TJ spring, PM me if your interested.
TJ Springs...
That is what I was thinking....
#5 | |
same ones i use and have for about 4.5 years with no problems at all plus with only being about 3.5" in diameter they are easy to place on the axle
One of these days Zuk 2.0 |
Rear soft top tracker/sidekick springs are 150s. Chris C. has them at all 4 corners and his Sammy does awesome!
