Old 11-18-2008, 09:23 PM   #1
sickws6
This is common. I have never done a body lift install or take-off where at least half the bolts didn't break or strip.
Cut the ones you can't get off with a sawzall. replace with better bolts.
How the hell so I get the broken part of the bolt out? Drill it out? Or is there away you can actually get to the top of the bolt?
sickws6 is offline   Reply With Quote
Old 11-20-2008, 03:26 AM   #2
You have to cut an opening in the floor to get to the nut it's incapsulated . Then just cut it out with a chisel or wizz wheel once your done and have installed new nuts and bolts weld up the floor , rattle can the welds and call it done.
Old 11-20-2008, 05:15 AM   #3
Actually the best way I have found to do it is the get as many bolts out as possible, then the ones you can not get out jack the tub up and cut the square plate that the bolt threads into out. This will be in a mount channel. After this is done drill through the floor of the jeep where you removed the "old square piece" and get carriage bolts to replace the old mounting bolts. You can use hex bolts if you do not want a more flush mount in the floor.
