Another idea would be to take a look at the cruise control setups on XJs & replace that cable with another "bike cable" type of setup that you could position at a certain RPM when welding was required.
#2 | |
Thanks. I'm amazed how it welds.
Decisions,Decisions... ![]() Nick
Well, if you're going to wire a switch to engage the second alternator, you could get a double-acting switch that'd do both at once: trigger the alt and the high-idle.
In fact, I could get you a big manly one you could mount right under the hood, next to the alt, so you hook up the cables, flip the "on/off" switch, and go. Robert
Did you just go to UPullandPay and asked what cars had a higher amp alternator? Also, I am planing the bike cable ish idea for the adjustablity.
I am putting in a control box under the hood with the switch there since I will have to hook the cables up and adjust the idle.
#5 | ||
Yep, My control box will be similar to yours. Nick
#6 | |
I am got some work ahead of me since I am keeping my AC comp since it houses my OBA. So I haven't figured out if the battert is moving or the air box is out of the picture.
#7 | |
That's the idea anyway... Ours don't have the fancy little arrow, just a white stripe... See ya
remove the air box Nate, keep a list of what parts you buy from where, I'd like to do this asap also. Do a cowl snorkle intake, that's what I'm doing next, that'll free up all your air box room.
