Jeepless
Trail Report
@%^#$, where is it?
It must have been pretty uneventful if noone has posted up. :mad: I have been doing my wheelin on the internet since the injury
I have some pic will try to post up later tonight.
things that I know went wrong. shawn keep brakeing U-joint bolt on his front axle XJ jeep Craford(sp) pulled his front shaft apart Toy truck Broody(sp) broke the studs that hold on the kingpin cap/his high steer Big YJ Bo broke rear bolt that hold the drive shaft to the rear yoke XJ jeep white Doug(aka Bear) pop a seal on his steering put it back it but keep leaking CJ5 |
Shawn driving an XJ now... cool.
Crawford has pulled a front shaft before... you need longer yokes, brother. What did Brody end up doing with the sheared kingpin cap bolts? Enough left to get them out? Did that muck up the balanced (dual) cylinder steering? At least Bear didn't roll... again. ![]()
series 10 PTO shaft is what they are useing
to keep the shafts together got pic's somewhere..
#6 | |
Jeff and I made a mad dash back to camp and picked up a spare tie rod with hiems, that Doug had in the back of his truck. found some big bolts and nuts and put conventional steering on the front of Brody's rig and very carefully drove it back to camp. Brody broke in the first set of shoots just after the split to school bus on the main trail ( going toward pink rock ) . I'll try to get a full report of at least our group up tonight sometime. Sarge |
here you go
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by kyrel69; 06-16-2007 at 10:00 AM. |
found them, power clutch and drive has
them in stock. the parts are made by Neapco, the male # is 72-2231 female is # 53-2415
buy 2 females and 1 male
split the cost with your buddy
how much are those?
Well I think Brody got some bolts to put in there and limped it back to camp. they all pulled into camp after we did. We had to pull Bo out after he broke his rear U-joint strap bolts
#14 | |
Your wifes pimp!
David, I can't belive you went along I have never heard of you or Scotty going anywhere but Haspin.:p Did Scotty go with you? Post up some pics!
#15 |
#18 |
Treasurer
I was also able to follow my group up every trail except one, and then i broke a strap on my rear u-joint on the last run and George had to hook up the strap to help me over in a few places, but i returned to camp under my own power. George,Jeff P. Jim and the rest of our group did well over 100 miles of wheeling.(Hay Sarge, we found the lake) where we went swimming and cooled of a little. This was the best C.O.R.E. run i have been on. A few more mods on the XJ and it will have to get even better. Great Ride, Thanks Guys.
#19 |
lets see those pic's folks. !!!
