How big a piece you need? I might be able to scrounge some scrap...
tri state plastics is a lot cheaper than ams, but be a longer drive if you just need a peice or 2 may not be worth it. its by where johnnys toys used to be in latonia ky.
60" x 48" would probably be on the large side but give me room to radius corners and rout(sp?) the edges. I'm aiming to make a back glass like this.
#4 | |
But I cut both my XJ doors from a piece not much bigger than that, I don't think my back window is much bigger than 18x42... :confused: Robert
You do not want to have original glass in it? Anything else scratches easily in time. Take a cardboard template to franks glass (next to fairfield bowling lanes) and get a quote on some automotive glass. They are reasonable sometimes.
Yeah, Robert it is going to be pretty big. I havent put a tape on it yet, but it is a good size. I rounded up on the guestamated size so that I could have room to work with.
Truggy, The CJ7 top is supposed to have a frame. I am afraid that even tempered glass would crack. If I bought the Liftgate piece, I could use the glass that I already have. OMIX-Ada and JC whitney are pretty proud of that fiberglass reproduction piece as it is priced between $280 and $450 plus gaskets, seals, etc. I have it in my head that I want to make this removeable so that it could stow between the roll bar and the hardtop. That way I could drive around like I do now. Drop the windows, stow the rear and take off.
Curbell Plastics, Zach Boehm, 513-742-9898
Piedmont Plastics, 733-9200 We use them for plastics (whoever has a cheaper price ;) ) |
I will 2nd piedmont plastic!
