Old 03-09-2011, 08:13 PM   #126
krawlin85toy
krawlin85toy's Avatar
Images: 76
Have'nt bolted up seats, but i have started putting primer on the body so I can see how much work I missed.
Pics never do any justice but here they are. hope you enjoy the slow process of this build.
ID:	3548   Click image for larger version
ID:	3549   Click image for larger version
ID:	3550   Click image for larger version
ID:	3551   Click image for larger version
Old 03-09-2011, 08:17 PM   #127
that thing is gonna be a sweet ride.... Don't get discouraged, it is looking good... You know it will be well worth it once you get it done...
Old 03-09-2011, 08:20 PM   #128
krawlin85toy
Images: 76
not the problem it takes forever to do body work,and only seconds to screw it up.
I have always been able to do the work,just hate the mess and smell of fillers.
thanks again for the props.
Old 03-09-2011, 08:32 PM   #129
yea body work does suck, i have done my fair share of it and it always seems to piss me off... i lose my patience if i screw anything up and have to walk away from it for a day or so...:mad:.... but once you get the majority of it done it will be on to the cool stuff...
Old 03-09-2011, 10:30 PM   #130
one good tree rash will make the rear body look great!
Old 03-09-2011, 11:17 PM   #131
Hotwheels
Hotwheels's Avatar
Chicks dig dents
Old 04-08-2011, 09:42 PM   #132
krawlin85toy
Images: 76
here are a few more pics! haven't had much time to work on it.
not sure if i will keep rack, but I figure I shortened the truck i will see if i could do the same with the roof rack.
ID:	3646   Click image for larger version
ID:	3647   Click image for larger version
ID:	3648   Click image for larger version
Old 04-08-2011, 09:46 PM   #133
krawlin85toy
Images: 76
more pics
ID:	3650   Click image for larger version
ID:	3651   Click image for larger version
Old 04-08-2011, 09:48 PM   #134
krawlin85toy
Images: 76
1 more!!:o
Old 04-09-2011, 08:42 PM   #135
Sweet.
Old 04-09-2011, 09:06 PM   #136
like you are really going to use the roof rack at what 23"....is that wat the note says....lol
Old 04-10-2011, 08:31 PM   #137
krawlin85toy
Images: 76
here aree a few more shots. borrowed a set of 39.5's to set up suspension. this way I can run my 37's and have no issues. Plus If I do buy new tires I can possibly run bigger tires in the future.
I set a 37 in front of the 39.5 as a refrence to see tire size difference.
ID:	3655   Click image for larger version
ID:	3656   Click image for larger version
ID:	3657   Click image for larger version
ID:	3658   Click image for larger version
Old 04-10-2011, 08:35 PM   #138
krawlin85toy
Images: 76
The rack is just for mostly looks.,and it can still be used.
In factory location and there are holes allready drilled in roof. If I don't put back in everytime it rains the interior would take on the rain.
Old 04-11-2011, 03:21 PM   #139
Hotwheels
Hotwheels's Avatar
looks good george
Old 04-11-2011, 06:03 PM   #140
Not worried about tree branches sticking it it?
Looks sick with the 40's.
Old 04-12-2011, 07:53 PM   #141
krawlin85toy
Images: 76
I was able to get the main frame support welded in and start finishing the radius on the rear section. I also cut a large section of the frame off. There is no turning back now.
I still have to remove more of the frame and box the back in. I would like to get all that done so I can start getting the back ready for tube work. Then I can decide the paint design I would like to finish it off with.
ID:	3665   Click image for larger version
ID:	3666   Click image for larger version
ID:	3667   Click image for larger version
Old 04-14-2011, 09:32 PM   #142
944drsk
1986 4runner
944drsk's Avatar
George-- your making me wish I had some 40" and a newer 4runner to cut up. I LIKE it!!
MODS- A Bunch Of Stuff That Seems To Get Me In Alot Of Trouble...
944drsk is offline   Reply With Quote
Old 05-05-2011, 06:51 PM   #143
krawlin85toy
Images: 76
I finally got to do a little work on the runner. I cut the frame off to where i wanted and trimmed the floor back more. I was able to get the frame boxed and welded in along with cleaning up all the leftover metal that was still on frame where i removed factory suspension.
I cut the floor pan the rest of the way out and getting it ready to make a new floor pan.
ID:	3703   Click image for larger version
ID:	3704   Click image for larger version
ID:	3705   Click image for larger version
ID:	3706   Click image for larger version
Old 05-05-2011, 08:56 PM   #144
looking good brother...
Old 05-05-2011, 09:49 PM   #145
krawlin85toy
Images: 76
Thanks,I also got the 5 speed pedal assembly mounted in.It's ot like the old yotas,where all the holes were marked or just had plates over the holes. Had to get the old hole saw out and cut the firewall.
I hope to start getting ready to do some tube work on the back half soon. The only problem is I have to set up a bender outside and the weather has been stupid. Will have to mount the bender,do the work and put it awawy each night.:) I guess I could use a bigger place, but who couldn't.
Old 05-12-2011, 11:51 AM   #146
Looks good... The roof rack and diamond plating to cool..
Old 05-21-2011, 12:57 AM   #147
krawlin85toy
Images: 76
finally started to get the rear floor pan going and fabed in, not finished but finally starting to get closer. Have a while to go.
Thanks pater for the help on the bends! you to brad.
ID:	3746   Click image for larger version
ID:	3747   Click image for larger version
ID:	3748   Click image for larger version
Old 06-07-2011, 10:20 PM   #148
krawlin85toy
Images: 76
I have been working like a mad man on this project trying to get it done in time for the July run to badland. have to say thanks to Chris on all his help thus far, and to Scott on his help so far with the tube work.
I got the drive line swapped out of the 85 and its now i the 94,need to swap intake out from a newer truck(thanks Hotwheels). got the front aaxle in and found that I had to move power steering box foward also.All the little things that making a new build such a pain. got box moved, now i need a longer steeringg shaft.:mad:.slow moving , but its getting there. forgot i had to remove body mount when I moved box up. more crap to fab up.lol
ID:	3859   Click image for larger version
ID:	3860   Click image for larger version
ID:	3861   Click image for larger version
ID:	3862   Click image for larger version
Old 06-12-2011, 10:57 PM   #149
krawlin85toy
Images: 76
I had a some help this weekend on this slow bus,thanks to all that stopped by and lent a helping hand.
I re-welded my slider brackets on and put gussets on them this round, may not have trouble with them coming up on a good drop off on rocks.( I hope):,
removed the factory alarm system, won't need that anymore. I started the painfull part of removing all the wiring I wont need anymore. I will be cutting it all down to what is needed.
I finished the floor and got liner on it, also got rear seatbelts mounted and ready to finsh mounting the rear seats as soon as all the wiring is finshed.
Hope all the pics are helping.
Name:	94 runner build 001.jpg
ID:	3884   Click image for larger version
Name:	94 runner build 002.jpg
ID:	3885   Click image for larger version
Name:	94 runner build 003.jpg
ID:	3886   Click image for larger version
Name:	94 runner build 005.jpg
ID:	3887   Click image for larger version
Name:	94 runner build 006.jpg
Name:	94 runner build 009.jpg
ID:	3889   Click image for larger version
Name:	94 runner build 010.jpg
ID:	3890   Click image for larger version
Name:	94 runner build 011.jpg
Old 06-13-2011, 10:19 AM   #150
Green Zuggy
Green Zuggy's Avatar
Images: 231
Looks great! Will it be ready for ZookiMelt?
You definitely need 39s for this rig. The 37s look so tiny! ;)
Jeff
