wow... that's a 5 year old pirate thread, funny.
this is a much argued topic... and people will swear on their lives that their answer is right. use what works for you and what you have on hand or available to you. myself, no sleeving for me. I will only use a solid wall tube. it's stronger. the air gap, no matter how slight, opens the door for failure of the tubing. If you could get a tube to slide into another with ZERO tolerance and gap, then it might be close, but still not as strong. you'd have to have an insane press to get it that tube in there, and the one yer sliding it into would have to have been bored to an exact dimension. Any discrepency would allow for a failure point. Don't buy 2 pieces of tube, just buy one in the size you want and never look back. Then again, I'm no engineer, I just have some real world experience. There's reasons I run .500 wall lowers on my rigs...
wow, i didn't think this thread would be this detailed. i watch xtreme all the time and i actually have learned some things from ian. he just did this on his supension arms for the current buggy he is building on that search and restore project. i've seen him use this method on steering links as well on his own show.
on his blazer solid axle rig he was working i noticed another part i didn't think was safe. on his drag link bar he has it bolting on top of the tie rod bar on the same knuckle(passenger side) using the same long ass bolt. to me it looked like the sheer point on the bolt would be moved to the distal end and from looks looked like it would snap pretty easy. |
I think it all has to do with the angle of the dangle............
Romans 7-8 |
as redriverranger can testify to.... i am lost. tooo many big words for my little brain. now on the other hand, if their were some naked girls in there i might understand a little more..lol
If Im mounting shocks to rearend i use 2.250 dia. 7075 solid alu. on lowers and if mounting shocks to arms I use 2.250 dia. with .375 wall chromoly tubing and have heat treated for strength. In my opinion in time the steel arms no mater how thick will bend.
