Jeep XJ
It has a clutch and electric fan. When it started overheating I replaced the water pump and thermo but, still randomly overheats. Jfiscus said maybe air pocket in head to remove temp sensor to bleed air out. Not tried yet. Might pull radiator to inspect.
Jeep 4.0
90' Jeep XJ Buggy - 5.5 custom lift, 33" TSL's, locked 01' Softail 01' Dodge Ram Cummins 3500 4X4 71' Dodge Challenger Shane ![]() |
Sounds like you have a good plan.
Jeep XJ
I will try to work it out by sunday I hope.
Chris (502EFI) and me want to go but he has church sunday..We might be there saturday morning and stay all day if it rains tonite..If anyone is going to be there saturday let me know and maby we can hook up..
Miamisburg,Ohio. Cell# 937-361-7267 90XJ Limited 4x4,4.0 Auto,NP242 Rustys 4.5" lift D30/D35,3.55 gears Denman Farmhand Tractor Tires 33x9.50x16 Work in progress http://smg.photobucket.com/albums/v2...0XJ%20Limited/ 1986 Chevy M1008 4x4 CUCV 5/4 Ton Truck 350ci,400turbo,D60 Front,14Bolt w/Detroit Rear 4.56 Gears, Desert Tan C.A.R.C. Paint. http://smg.photobucket.com/albums/v2...0M1008%20CUCV/ Last edited by fredrader; 09-07-2007 at 05:40 PM. |
Scott,
I'll leave Middletown about 0800 Sunday morning. I assume you will post up early that morning if you are advised of conditions that cause you not to go. I will PM you for a cell phone number incase I have trouble finding the park. I too, will be watching the temp gauge. But it is a shake down ride.. John
#8 | |
Jeep XJ
Pulled radiator looked ok, I found a small crack in my reservoir. My reservoir is pressurized from factory with no radiator cap. I will try to repair. New one is $40.00
Jeep XJ
Loaded and ready to roll to Haspin tomorrow. Are you guys still going. Be that around 9:00am
Last I heard we were on. Planning to meet at the main entrance around 10am. I see the forecast is 70% rain now. Truggy said he would call a friend in the morning, and if it's raining would post up if he wasn't going. Figure we'll check before we pull out here around 8ish (I have to get Starbucks on the way ;)). Hope to see you tomorrow!
Dodge Truggy
check throttle position sensor if it is bad it will make motor run lean thus run hot
