Old 07-17-2012, 09:53 PM   #1
acousticrawk
The MacDaddy
Send a message via AIM to acousticrawk
got the tv adjusted correctly! still shift in the wrong places. any suggestions?
acousticrawk is offline   Reply With Quote
Old 07-18-2012, 09:02 AM   #2
ZJ's had a bad problem with cracked valve bodies. New VB is about 100 bucks and easy to swap . this should fix your shifting issues.
Old 07-18-2012, 03:42 PM   #3
tjrider
4.0s with odb2 don't like to run without a cat. The downstream o2 sensor will keep throwing a code. Also, 4.0s will default lean when an o2 code is sent. So put a cat on it first and see what happens. I put those E3 plugs in my tj and it didn't like them. Autolites are the best.
